Zum Hauptinhalt wechseln
The Chevrolet Cavalier is a compact automobile produced from 1982 to 2005 by General Motors.
140 Fragen Alle anzeigen
Why is not charging the battery?
1997 chevy cavalier z24--2.4engine
i was driving for a week with the little
battery symbol drawing flashing in red
and after the battery was completely discharged.
Update
a red icon came up on my dash board it is a box with water and an arrow pointing down what does this mean
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Althea it is better if you ask your own question if you expect to get an answer. if you tag your question on as an answer to a question that is a few month old, nobody knows that you asked a question. It is not hard to do. Anyhow, your symbol is the low coolant (antifreeze) Make sure the engine is cool before you open the cap and top-up the cooling system.
Check your system for leaky hoses, leaking radiator etc.
von
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
Check the belt on your alternator. Check the cables from the alternator. Use a multimeter to test the alternator.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
1: If your battery light is on while the engine is running, your Alternator is not producing any charging power. Check the cable connections or have the alternator checked. It may need replacement.
2: That icon means you should check your coolant, because it is running low.
Bewertung 1
make sure your battery cables are clean and tight. check with 8mm wrench
Bewertung 0
I have put a new altanater on it and it does not charge
Bewertung 0
1 Kommentar:
Check all your fuses and battery connections, and the charge state of your battery itself. If it's a new alternator, then the problem is somewhere in the fuses or wiring.
von
I put a new alternator, starter, and battery. the car is still not charging. not sure what the reason is
Bewertung 0
Antwort hinzufügen
ELIEZER ROSARIO wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 5,723
