Zum Hauptinhalt wechseln
Vom Mercedes Typ W123 gab es verschiedene Modelle wie 240D, 300D, 300TD, 280E und mehr. Es handelt sich um Limousinen, Coupés und Kombifahrzeuge aus den Jahren 1977 bis 1985.
116 Fragen Alle anzeigen
W123 300 coupe rear window
Doing online research about rear window problems ( not rolling all that way down) I've found that is a very common problem, however, answers never seem to be accurate on how to approach the problem, some guiding towards regulators, others to switches etc .
My own problem is that window stop rolling down , when is 3/4 open and 1/4 left to be totally .
Can you please share some data base on your experience at this matter ?
Thanks you very much .
Mauricio Q.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your best option would be:
Check power to switch
Check power from switch whilst !#^&^$^ button(do this at regulator/ motor)
Now if they both equal around 12V
If you can see the rails make sure they look right
Now with the motor removed You will have to "bench test" motor/ regulator when doing this make sure it rotates though full motion
If it doesn't then that is problem
I can possible suppy a wiring diagram later today or tomorrow
Best of luck
Alex
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thanks Alex, will do. Look forward to ques diag,
von
hi
sorry about this but i could not find a wiring diagram
von
Antwort hinzufügen
Mauricio wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 993
