Zum Hauptinhalt wechseln
Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Fragen Alle anzeigen
Why is my front right Indicator not working,bulb ok
I have a XL1200 Harley Davidson Sportster 2012
It came on yesterday 9/6/2016 as i was turning right,then suddenly went out and on dashboard little green arrow flashing rapid?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Check the rear bulb as well when one goes the other acts weird so check to see if the rear bulb is bad
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks Jim i will check rear indicator just in case that is the fault.:)
von
Hilfreichste Antwort
Sam "little green arrow flashing rapid" is caused by the indicator not working. Make sure that the bulb is indeed okay, I'd replace it anyway. If a new bulb is not working as well, check the wiring going to the indicator. Make sure that it shows continuity.
Bewertung 2
1 Kommentar:
Funny enough the indicator decided to work in the rain,touch wood its still working now,but i will check back indicator like you said,thanks oldturkey :)
von
Antwort hinzufügen
SMUDGER wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 1,569
