Zum Hauptinhalt wechseln
Die vierte Generation des Surface Pro Tablets, erschienen am 26. Oktober 2015
210 Fragen Alle anzeigen
Can I replace the hinge or kickstand of my Surface Pro 4
I accidentally stepped on my Surface Pro 4, and one of the hinges on the kickstand broke. Rather than replacing the entire device (I do have a warranty) I would rather try to fix it myself. The left friction hinge still works fine, but is not strong enough to hold the device alone. The kickstand itself is not cracked and would not need any replacement, only the right hinge is damaged.
Thanks.
Ist dies eine gute Frage?
Bewertung 8
1 Kommentar
answer is not even about the hinge, only addresses the easy answer
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
Microsoft Surface Aufsteller austauschen
War diese Antwort hilfreich?
Bewertung 2
4 Kommentare:
answer does not address the broken hinge!
von
not a solution, it the hinge it broken it wouldnt help to put a new kick stand on
von
not any help it is not the kick stand it is the hinge. could not vote you down don't have a rep yet
von
Same comment from me, answer doesn’t address issue of broken hinge, which I also have. From what I could find you either have to tear down the product to remove the hinge or purchase a case with its own stand.
von
not helpful--hinge broken & not the stand
Bewertung 2
yeah my hinge is broken
i found this
http://www.powerbookmedic.com/Microsoft-...
Bewertung 0
Hi Grant,
To replace the right hinge, you'll have to open up the tablet. You can do this by following this very helpful repair guide!
Microsoft Surface Pro 4 Scharniere am Aufsteller auswechseln
Bewertung 0
Antwort hinzufügen
Grant Smith wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 21
Insgesamt: 15,587
