How can I check if the power supply is broken.
Ist dies eine gute Frage?
About 2 years ago, I found a way to test a G4 MDD's power supply, what you need to do, is make sure it is plugged in, and connected to the motherboard. Using a volt meter and a paperclip, check the connection between pin 14, and any ground (Pin 13 for example) by probing into the top of the connector. If it works, you should get +5 volts. you can use this photo for reference of the PMG5's pinout.
War diese Antwort hilfreich?
Pin 1 and any ground may also work
+ put the black lead of the multimeter in pin #1 and the red in #23. You should get +5 V
Between you and Nic i tested mine, tells me my PS is good, now to figure out what else the issue is...
I Have A Power Mac G5 (A1047) With Dual Prosessors and what i had to do was connect the 12V (Pin 23) to the Power On (Pin 14) and spun the fans perfectly. Try that as well.
--Nic
Just did that, I have the model that the orig post mentions and was trying to figure which ports as 13 is empty. The image that chris posted was helpful as well!
Letzte 24 Stunden: 3
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 4,471
