Zum Hauptinhalt wechseln
The 2009-2014 Ford F-150 was introduced for the 2009 model year as an update of the Ford full-size truck platform.
73 Fragen Alle anzeigen
F150 2014 Iwe4x4 grinding and rubbing sound in 2wd and In 4wd
I have a 2014 stx 4x4 that keeps having grinding and rubbing sounds coming from the front end. Sometimes it comes when just driving in 2wd the other times when shifting into 4wd. I took it to the dealership 3 times so far. The first time they said they replaced all 3 IWE'S. The sound went away for a week. So I took it back the second time they replaced the front axle and the solenoid for the IWE. They had it for a week this time I picked it up friday and its still making the whinning and grinding sound like its partially engaged. The truck was sold to me certified pre-owned and only has 19,000 mi. Has anyone else had these same problems?
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Hey James,
I found a forum post that might help. Check This out. Sounds like if you already replaced the solenoid, you may have to replace the IWE. There's a trick in there about driving 4x4 or pulling vacuum lines to have the truck drivable.
Cheers
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks I'll check it out
von
I believe there is a technical service bulletin (TSB) for this issue. I had the same issue and the repair included installing a vacuum check valve at the solenoid.
Bewertung 0
Se dañó la climayera y no ay porque es electrónico
Bewertung 0
Antwort hinzufügen
James Starrett wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 26
Insgesamt: 8,996
