No reverse on my golf cart
My electric golf cart lost its reverse can I fix it myself or do I have to take it in to a service center?
Ist dies eine gute Frage?
@gerryr, this could be as simple as the reverse switch being the problem. It is a mechanical contact and could be not making the connection. You can check that by switching the wires from the forward/reverse switch and see if you now have only reverse. If so, you know it's the switch. You did not tell us if your cart has a backup beeper and if it still comes on. Also, let us know if this cart has a dash mounted toggle switch.
War diese Antwort hilfreich?
2008 yamaha cart with back up buzzer
what if its not the switch?
I replaced the forward reverse control board. Now I have no reverse. Reverse worked prior to replacing control board.
@mikegolf have you tried to switch the wires to see if you then have reverse but no forward?
Hi my ez-go 2005 txt cart suddenly decided to not go in reverse ! the reverse alarm sounds but the cart won't go ! it will run forward when I push on the rocker switch. I checked the contacts behind the switch and they are ok no broken or frayed wires.
mine was the micro switch on the passenger side of the forward reverse switch. I just bent the prong put on the lower side of the metal just below the white tip of the switch. This way it pushes further into the switch housing.
Letzte 24 Stunden: 15
Letzte 7 Tage: 130
Letzte 30 Tage: 567
Insgesamt: 57,033
9 Kommentare
Would you give us your model number?
von mayer
EZGO textron serial number 833198
von gerry
@gerryr and the make of your cart as well :-)
von oldturkey03
I find nothing but EZ-GO on the cart
von gerry
Okay lets get to work. Based on your serial number you have a :
Make: Medalist
Type: Electric 36 V
Model: Electric Medalist
Year: 1994
Sounds about right?
von oldturkey03
4 weitere Kommentare anzeigen
