Zum Hauptinhalt wechseln
Repair guides and support for Dell Netbooks, a class of small, lightweight laptop computer from the late 2000s.
17 Fragen Alle anzeigen
A cabinet file necessary for installation cannot be trusted
A cabinet file necessary for installation cannot be trusted. Please verify the Cryptographic Services are enabled. When i tried to install directx i got this message " A cabinet file necessary for installation cannot be trusted.
How to solve this..
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 12
5 Kommentare
how to verify cryptographic services are enabled
please replay to hurryup
von
please help me
von
@shahzaib khalil
Try this!
Set Cryptographic Services to automatic Set the Cryptographic Services to Automatic, and then try to install the program again. To set the Cryptographic Services to Automatic, follow these steps:
Start the Administrative Tools utility in Control Panel.
Double-click Services.
Right-click Cryptographic Services, and then click Properties.
Click Automatic for Startup type, and then click Start.
Refer: http://support.microsoft.com/kb/822798/ and follow all the methods listed in the KB article.
Man is the only animal that laughs and weeps; for he is the only animal that is struck with the difference between what things are and what they might of been.
von
mercy.the best wishes for you
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
Hey Bro, I don't know if you still have issues with this but this is for anyone how is still experiencing this issue when trying to install DirectX.
I searched for hours and struggled to get this fixed, long story short I finally got it fixed!
Please try using the following link. Note: this is not a scam nor virus , it's from the official website (Microsoft)
https://www.microsoft.com/en-us/download...
Installing that fixed my issue.
1.Create an empty folder (The folder's name isn't important, just leave it blank for all I care)
2.Put the directx_Jun2010_redist.exe (That you just downloaded) into that empty folder.
3.Install/open the "directx_Jun2010_redist.exe"
4.Scroll through all the contents that were extracted, look for "DXSETUP.exe" and Install that.
5.Click through the on screen instructions and allow it to complete.
6.What are you still doing here you're DONE!! :)
War diese Antwort hilfreich?
Bewertung 66
36 Kommentare:
thanks, its work
von
I just registered to thank you. Your solution solved my problem after hours of struggling. Thank you very much!
von
von
Thanks alot bro..
It worked....
Legendary
von
Thank you very much. I had to register to thank you
von
31 weitere Kommentare anzeigen
This is what I did and it worked!!!
1. navigate to \Windows\System32\directx\ or \Windows\SysWow64\directx
if you have Windows 7 x64.
2. Click on "organise" file menu, then "folder and search options" then
in the "View" tab check "show hidden files and folders" and then "ok"
3. websetup folder will be visible now. go in there and delete all
contents.
4. run "dxwebsetup" again.
Works for me under Windows 10 64bit.
Bewertung 2
3 Kommentare:
Thanks man!!!! i was going gray over here that really helped
von
Most welcome
von
When I try to run dxwebsetup I get some error about a cabinet file and cryptographic services
von
ممنون در رفع مشکل من خیلی موثر شد.همیشه پر توان باشید.
Bewertung 0
Antwort hinzufügen
Winkigreen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 18
Letzte 30 Tage: 72
Insgesamt: 44,274
