Zum Hauptinhalt wechseln
Amana Refrigerators are manufactured by Whirlpool Corp group, in Amana Iowa.
24 Fragen Alle anzeigen
Why does Ice Maker take so long to make Ice Cubes
I recently replaced the water filter on my Amana refrigerator, now the water flows fine, but the ice cubes seem to take about 6 hours to dispense a new batch. Prior to changing the filter, they would freeze and dispense in about 2.5 hours. Now the cubes are larger, but it seems to take a long time to make a new batch of cubes.
Does anyone know, how the dispenser determines when to eject the cubes ? Is hat something that is adjustable ?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
There is a temperature sensor on the ice maker. There is also a heater to help the ice slide out and there are several gears in the ice maker. None of these are adjustable. Several components other than the ice maker could cause slow ice production also. A bad fan motor, bad door gasket or a leak in the sealed system.
War diese Antwort hilfreich?
Bewertung 4
4 Kommentare:
I just bought my GE Refrigerator/freezer in Oct. The ice maker is not working. What should the temperature be? Serial #LQ206510 Model #GSS20ETHWW
von
Rachelloyed-the default temperature settings are 0*f in freezer, 36*f in fresh food.
Your refrigerator is covered under the manufacturers warranty for the first year. That includes parts and labor. You should have a qualified technician check it out thoroughly.
If you attempt any repairs yourself, it could void the warranty.
von
what should temp be in my jenn air freezer? right now its at 5 degrees. the ice maker works because I pour water into it and cubes came out. but if i dont pour water it doesn't throw out cubes?
von
0* freezer 36* fresh food.
The ice maker needs the freezer tempature to be less than 9* or it won’t advance.
Sounds like your problem might be the water inlet valve or frozen water line to ice maker.
von
Antwort hinzufügen
richgrooms wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 16
Letzte 30 Tage: 52
Insgesamt: 12,177
