Zum Hauptinhalt wechseln
Repair guides and support for budget electronics manufacturer Tagital.
45 Fragen Alle anzeigen
Why wont my tablet turn on
it wont charge wunt turn on
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Ann Shipman, There could be a few reasons for your device not charging and powering on. Faulty charger/cable, faulty battery, faulty charge port/connection etc., you could try a factory reset as described in 1st link below. Other links may help in trouble shooting your device if reset does not work. Good luck.
http://www.femitechservices.com/2016/04/...
https://www.youtube.com/watch?v=DSGAHFsn...
Tagital T7X Troubleshooting
Tagital T9X Battery Replacement
Tagital T7X Battery Replacement
Tagital T7X Battery Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
5 - 10 minutes
Tagital T9X Battery Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
25 minutes
War diese Antwort hilfreich?
Bewertung 2
I'd suggest opening up the device and making sure that everything is appropriately Connected to your logic board. if not then find the plug and re connect the cable to the device. If you see nothing wrong with that, see if the charging port is loose, as this is common in low budget devices. If you see nothing wrong with that then I'm sorry, But your tablet had its run.
Bewertung 0
Antwort hinzufügen
Ann Shipman wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 736
