Zum Hauptinhalt wechseln
The Canon PowerShot G11 is a point-and-shoot digital camera designed to be easy to use for photography enthusiasts.
12 Fragen Alle anzeigen
Do you have a guide for replacing the LCD and the LCD cover?
On my Canon PowerShot G11, the LCD is broken and the case that holds the LCD is dented. I need to replace the LCD and the case as a unit. Do you have a guide for doing this? If not, is this something that I can figure out based on your guide for replacing the rear cover?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
@jthomson29 this should work for you:
You may have to do a bit of searching but every now and then parts are available at places like this.
War diese Antwort hilfreich?
Bewertung 1
I am pretty sure you could figure it out from the rear cover replacement guide, it looks like it is just two or so more screws then it comes off. The problem is going to be finding a replacement that comes as the whole unit not just the screen.
Bewertung 0
Antwort hinzufügen
Jim Thomson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 234
