Zum Hauptinhalt wechseln
This guide contains links and information to help users repair a Craftsman 16 gallon Wet-Dry Vacuum. Model #113179930.
2 Fragen Alle anzeigen
How do I find replacement front casters for vacuum cart?
I'm trying to fix the front casters on a cart for a Craftsman 16 gallon wet/dry vacuum. The vacuum is model #113179930. Sears has a very helpful exploded view diagram for the product:
http://www.searspartsdirect.com/model-nu...
The casters I need are #23, Parts #: 73237. However, it seems they're no longer available, at least from Sears:
http://www.searspartsdirect.com/part-num...
Sears no-so-helpfully suggests: "The manufacturer no long makes this part, and there's no substitute part. If you choose to purchase a new product, please visit www.sears.com"
The current casters I believe have a completely missing roller bearing and therefore no longer will stay upright:
The casters slide into these attachments on the front of the vacuum cart:
Any advice to:
1) Find the exact replacement part
2) Find a suitable replacement I can install with the existing mounts
3) Come up with an entirely new wheel and mount system to pull wheels back on the front of the cart.
Thanks!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
@luke give us some measurements. Shaft diameter and length as well as caster diameter will help us to help you:-)
von
Try www.CasterHQ.com for their grip ring stem casters. They were the cheapest online and shipped right away.
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
@luke , Luke Soules , If you have an old caster assy. take it with you to hardware/surplus store to compare with what they have in stock as they may have a replacement. Posted a few links below for replacement stem casters. Good luck.
http://www.homedepot.com/b/Search/N-5yc1...
https://casterconnection.com/casters/ste...
http://www.faultlesscaster.com/page.php?...
War diese Antwort hilfreich?
Bewertung 5
Hey luke, the cheapest casters I have found are from source 4, and they also have a guide for measuring them to know you're getting the right one:
https://source4industries.com/blog/how-t...
Bewertung 1
Hey Luke,
Checkout this link to CasterHQ, they have a huge selection of 7/16” grip ring casters available with different wheel materials.
https://www.casterhq.com/Grip-Ring-Stem-...
Bewertung 0
Hi Luke,
I guess this is an old post, but I rebuilt my vacuum with wheels from www.castercity.com
Better than amazon, but a little more expensive.
Bewertung 0
Antwort hinzufügen
Luke Soules wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 756
