Zum Hauptinhalt wechseln
Repair information and disassembly guides for pressure cookers.
19 Fragen Alle anzeigen
Opening pressure cooker to replace LED board? How?
I need to replace the LED PCBoard on my electric pressure cooker as the LED display is broken. I managed to get the spare part from an appliance spares place, but now I have no idea where to open the Pressure cooker (easiest way), to swop out the old board for the new one. PLEASE HELP :-) - Cuisinart Electric Pressure Cooker CPC-600 or AEG/Electrolux EPC600.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
Where did you get the LED board?
Thanks!
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
I just can't find any teardowns or repair guides on this. These people sell the parts and have a toll free number and may be able to assist you: http://www.ereplacementparts.com/cuisina...
War diese Antwort hilfreich?
Bewertung 2
You have to undo all the screws from inside and slide the outer case off there is a screw underneath a label and the front panel peel off label there should be to screw underneath at the top when you have done that there are 4 screws holding the panel on for the led circuit board I have done one my self so please put all the screws in a safe place as I did so you don't lose them I hope this helps you
Bewertung 0
2 Kommentare:
I hope this helps you out
von
where can you get the led display Pressure king pro 5l
von
Antwort hinzufügen
Phillip wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 21
Insgesamt: 3,175
