Zum Hauptinhalt wechseln
Released 2015 Model Number: POLSP01W
66 Fragen Alle anzeigen
Red light is blinking
My Polaroid SNAP wont print out pictures. The 3rd red light is blinking. Do I need a SD card that way it can work? Someone please answer ASAP.
Ist dies eine gute Frage?
Bewertung 7
3 Kommentare
I have this problem too, how did you solve it?
von
i also have this problem. how am i supposed to take pictures?
von
Me too ,how do you fix it?
von
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
@anonymous__ ,Anonymous, Find below links to troubleshoot your Polaroid SNAP, If the camera is still under warranty and problem persist after using the trouble shooting guide link #1 and your manual link#2, then use link #3 for contacting Polaroid support and warranty. Good luck.
Polaroid SNAP Troubleshooting
https://www.polaroidsnapcamera.com/skin/...
https://www.polaroidsnapcamera.com/snapc...
War diese Antwort hilfreich?
Bewertung 2
No you do not need an SD card to take pictures. You can either have the film OR the SD card. Or both! The red light is just telling you its missing whatever the red light is flashing in.
Bewertung 0
I think I know how to fix the problem. The camera is very picky depending on how you put the film in make sure the part that says sink zero ink is facing downwards and the blank part should be facing towards you.
Bewertung 0
I had this same problem. It was an error with the paper, I had to keep playing with it a little. I bent the stack of paper a little the other way to straighten it out as it was bent just slightly and then i pressed hard on the back when I closed it. I think that helped get the paper in place…
Bewertung 0
Antwort hinzufügen
Anonymous wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 43
Letzte 30 Tage: 165
Insgesamt: 29,645
