Can the CPU be upgraded in in my Toshiba Satellite C75D?
I would love to upgrade the processor of my C75D?
Ist dies eine gute Frage?
The processor can not be changed out. If you're looking for more speed, I would suggest installing more RAM and a solid state drive. As far as technical limitations are concerned, the motherboard can handle up to 16GB of 1333Mhz DDR3 SODIMM, running at 1.35v. The brand doesn't really matter, as they all do the same thing.
Any 2.5" solid state drive will fit, and the prices have come down considerably. There are a lot of 480GB drives available around $130 +/- on Amazon. You'd notice a huge difference with just the solid state drive.
War diese Antwort hilfreich?
DDR3 running at 1.35v is DDR3L. The L stands for low voltage. Standard DDR3 is 1.5v.
However, it isn't always listed as DDR3L. Crucial and Kingston both have RAM offered at 1.35v without the "L" indicator. As I'm sure many other companies do, as well.
I am aware of that. Normally when they do that, the ram is cross-compatible.
Bobby Hayes , From what I have read on the forums, your processor is soldered to the board and is considered not up gradable. Good luck.
DARN! Thanks for the info!
darn is the light name for what I consider to that, why would they do this when other processors are easy removed I just found out this in 2019 im guessing the info about my processor is that it is an 4 core which helps in the top few over the 2 core so I just upgraded my ram and hd almost time for another step up …..
Hello, I own a Toshiba laptop model C855D-S5351 socket FP2 (827) processor AMD A6 - 4400M Can I upgrade the processor to a newer version and what is the version number Thank you very much
I have a A505 and the cpu is a socket processor it is not soldered.
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 34
Insgesamt: 6,740
1 Kommentar
There may be a something you could do to make your PC faster besides a CPU upgrade. What exactly do you need from your laptop?
von George A.
