Zum Hauptinhalt wechseln
A digital camera designed and manufactured by Sony in 2012. A 18.2 megapixel camera with Wi-Fi, GPS, and a memory card slot.
16 Fragen Alle anzeigen
How to do a factory reset?
I've gone thru all the options on the Sony eSupport pages, it's a no go.
The power lite goes on, but nothing else works. The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off, which may be an error code? The power lite goes off only if I remove the battery.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@paulieh01 this should work to reset your camera:
"The lil red "access lamp" (#25 in the manual, next to the sd card) flashes 2x then off" is an indicator for the memory card. You may have some problems with the card. Remove and/or replace it it and see if that changes anything.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Paulie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 20
Insgesamt: 2,145
