Why is my door ajar light staying on?
On my 1997 F150, all doors are shut but my door ajar light and my overhead light will not go off.
Ist dies eine gute Frage?
Austin Simpson, It is usually due to a sticking switch in the door latch #1 on diagram. Take some WD40, spray the latch on the door all direction especially try to get around #1 on diagram soak it, open and close the door firmly/hard 10-20 times and spray it again. This will most likely clean/lube up contacts. Follow up with a better lube graphite/silicone spray lube after a couple days. Check the link below, may help.
If no luck you may have to change the defective switch. Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check
War diese Antwort hilfreich?
thanks never thought to try this
a couple of weeks before this started I sprayed all door parts with wd40
maybe mechanisms are clogged or dirty will try your ideas
Don’t waste your time pulling the switch and cleaning it. Even when that works it is generally temporary. Replace the part. Also, as far as diagnosing which door, is the key in dinger also going off? If yes, drivers door. If no, any other door, but usually passenger front. It is not an issue with dirty contacts, but rather a plunger that gets sticky.
your suggestion worked
Thank you
The switch may be physically broken and cleaning and lubing may not fix it, but of course it is a great first step in the troubleshooting process.
Or, find the lighting intensity control knob for the dash instrument panel located driver side left of the steering wheel.
Lightly roll the knob up or down; when all the way up, it also keeps the cabin light on.
Letzte 24 Stunden: 2
Letzte 7 Tage: 43
Letzte 30 Tage: 204
Insgesamt: 17,466
2 Kommentare
My Mitsubishi lancer driving said door closed but not off door ajar warning light
von Haris Peringattuthodi
My Mitsubishi lancer all said door closed but not off door ajar warning light
