Zum Hauptinhalt wechseln
Die vierte Generation des Surface Pro Tablets, erschienen am 26. Oktober 2015
210 Fragen Alle anzeigen
Blurry texts and screen flickers
Texts are blurry, screen flickers and video/image moves under frozen one.
How to correct it ?
Image and text on the screen use to tremble, up and down, from time to time. When this happens image and text become blurry.
When video is playing,sometimes, one frame freezes, while in the background the video is still playing.
Is it a software related problem or a hardware malfunction ?
(once I hooked the Surface to a monitor, the video played fine,while the problem persisted on the Surface screen)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
11 Kommentare
Hi,
If it was software it should also affect the external monitor.
It could be a video cable or a tablet screen problem.
How long have you had the tablet?
von
I have the same problem with my Surface pro 4, which I have had only for about 18 months, the problem started several months ago, and is getting worse. It makes it very hard to do projects! I have searched the Internet to see if there is a way to fix this problem. I love the Surface Pro 4, but unless Microsoft comes up with a solution, I would not buy another of their products like this! Microsoft needs to fix this, as many are experiencing the same issue!1
von
My surface screen is going blurry, looking like multiple docs are open on top of each other. Can’t read any of it. Screen becomes unresponsive. Does anyone have any advice? Thanks
von
I am experiencing the same thing on my surface pro!
von
I just started having this problem. My surface pro 4 is about 17 months old. Happens when the device gets hot.
von
6 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Call Microsoft, this is a known issue covered by extended warranty.
War diese Antwort hilfreich?
Bewertung 2
This worked for me. https://www.groovypost.com/howto/fix-fuz...
Bewertung 0
Antwort hinzufügen
Emilcar Similien wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 16
Insgesamt: 16,942
