Zum Hauptinhalt wechseln
Der Xbox Wireless Controller 7MN-0001, hergestellt von der Microsoft Corporation, ist der am meisten für die Xbox Spielekonsole verwendete Controller, der auch für PCs verwendet werden kann.
127 Fragen Alle anzeigen
Broke LT and RT holders how do I replace it?
I have provided two pictures, the blue controller is the one that I'm trying to fix. The dissasembled controller is the one I'm using for the RT and LT.
I want to remove the Trigger holder from the controller but don't know how to do it.
It's the metal piece holding the Triggers.
I need help guys.
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
Hello, my RT button on my Xbox One controller is not working correctly. When I get on NFS the car drives by its self.
von
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
https://www.youtube.com/watch?v=NZp8Rcik...
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Thanks for that
von
Hello @imzai,
There is no photos as I can see, did they upload correctly?
Well, I provided a few IFixIt links that may help
Xbox One Wireless Controller Vibrationsmotoren Austausch
Xbox One Wireless Controller Tasten Ersatz
I hope these help!
Thanks,
Keegan
Xbox One Wireless Controller Model 1537 Vibrationsmotoren Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
15 - 20 minutes
Xbox One Wireless Controller Model 1537 Tasten Bild
Anleitung
Schwierigkeitsgrad:
Schwierig
30 minutes - 1 hour
Bewertung 1
3 Kommentare:
I have edited my post, I've uploaded the pictures, what I mean to to remove from dissasembled controller is the metal stick holding the triggers.
von
Okay I see, so if you look back in to the link Xbox One Wireless Controller Vibrationsmotoren Austausch it shows how to remove the moters. So, I think by the look of the photos its soldered to the board. Can you confirm this?
von
You have to press the small part of the metall pin then it comes out on the other side where you can grab it with pliers / tongs / nippers and pull it out gently.
You have to be very carefull, else you destroy the trigger or the frame.
Bewertung 0
I need a LT trigger spring
Bewertung 0
How to take this off lt button
Bewertung 0
1 Kommentar:
Same here, my rigger holder is broken too
von
My left triggers has came out of the socket please help
Bewertung 0
Antwort hinzufügen
J Angel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 31
Letzte 30 Tage: 105
Insgesamt: 29,214
