Zum Hauptinhalt wechseln
The Lenovo IdeaPad Yoga 11S is a 2015 2-in-1 convertible laptop with an 11.6” multi-touch display.
24 Fragen Alle anzeigen
Why is my keyboard and touch screen not working?
My keyboard isn't working and it's also touch screen and that's not working also. None of the keys work. My screen pad to scroll the arrow is also not working. It's impossible to access my laptop because nothing is working at the moment. Could that be a sensor, or what should I change to fix this? Appreciate all help! Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
In order for you to get access to you data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
In order for you to get access to your data, try using a USB keyboard and mouse. If the usb peripherals work, you may want to backup your data. Secondly, in order to assess whether the problems are hardware or software related, you may want to try to restore the OS with the restore partition or use a "live" OS like Pupply Linux. If the USB ports don't work as well, then it mostly is a hardware problem and would require you to disassemble the unit (depending on your skill level).
von
Antwort hinzufügen
Armando wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 2,340
