Zum Hauptinhalt wechseln
Die DJI Mavic Pro ist eine kompakte, faltbare Drohne, die Videos in 4K Qualität aufzeichnet. Sie kam im November 2016 auf den Markt. Modellnummer: M1P Modellnummer der Fernbedienung: GL200A
41 Fragen Alle anzeigen
Left rear arm support replacement part?
I had a small crash that bent up a small plastic support piece for the left rear arm.
The drone still flies, but that rotor isn't flying parallel to the ground anymore (even with some duct tape support): https://goo.gl/photos/xxZGB68M9ZvfhDt16
top view and rear view (broken support is covered in duct tape)
I found Where to buy replacement parts, but I can't tell if this part is part of the middle frame, upper shell, or bottom shell since it doesn't look like it's connected to the top or bottom shell.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Alright, I figured it out. That piece is called the saddle, and it's connected to the arm.
I can't find anywhere to buy just the saddle, but by searching "dji mavic pro left rear arm" on ebay I found an entire arm with an intact saddle for $30 with shipping.
It looks like you can also buy them from Cloud City Drones, but they're out of stock at the time of writing.
Will update when it comes in!
2017-07-18 edit: it came in! Confirmed that that piece is part of the arm. Replacement was pretty straightforward - just a bunch of screws and minimal soldering. Some parts of prying the case apart were tricky, but nothing harder than an iPhone screen repair.
War diese Antwort hilfreich?
Bewertung 3
2017-06-12 Update: those two side plastic parts that come with the middle frame aren't the same pieces. I'm still trying to track them down.
Figured it out as I was typing out the question.
These side plastic parts are part of the middle frame, which you can buy on ebay by searching "dji mavic pro middle frame". I found a middle frame with two side supports for $15.
I imagine it would be easy to 3D print this part - it's just a flat piece of plastic with a hole in the middle.
Bewertung 2
1 Kommentar:
Thank you so much! You just saved me hours of research. I just knocked my mavic pro out of the top of a 70' post oak with a dog ball thrower (that took awhile), and broke the left rear arm stop when I caught the drone. Going to look for a middle frame now!
von
Antwort hinzufügen
Christian Genco wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 13
Insgesamt: 3,898
