I have gas in the oil. I am assuming it is the head gasket?
I am not sure how to tell the year of my club car golf cart.
Ist dies eine gute Frage?
Bill Wells, Usually with a blown head gasket the engines will tend to smoke quite a lot from exhaust. Other generic things that could allow gas into oil of engine, fuel float in the carburetor being stuck in the open position due to dirt/gumming(remove carb. check/clean set float level). Other possible causes, fuel shut off solenoid stuck(if equipped) allowing fuel to flow when key off, choke sticking on, air filter clogged acting like a choke, faulty fuel pump if vacuum type can allow gas to leak internally to engine if pump is leaking internally, if more then one cylinder(running engine with a dead weak cylinder/plug could allow excess gas into engine). Links below may help in trouble shooting your golf cart, 3rd link is a club car service/repair manual. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=U08g_ruy...
War diese Antwort hilfreich?
Normally Blown Head Gasket Symptoms are:
If you guess having gas in oil, the first thing to check is the fuel pressure regulator. Now, remove the vacuum line attached to the regulator and check if there is any raw fuel, there shouldn't be. A vacuum can be applied to the regulator and it should hold vacuum without leaking off.
Now if the regulator is in good condition, then there’s a chance of poor engine performance, which can cause replacing head gaskets, only if you observe overheating troubles.
Other possibles reasons could be like:
Insignificant amount of gas: The piston rings are seals placed tightly against the cylinder walls, to prevent the gasoline from flowing into the oil. But they don’t provide perfect sealing, hence a slight amount of gas will find its way into it. So it is advised to change oil as and when required.
Excessive Fuel: When a fuel injector is stuck open, the fuel will flood out. Gasoline will surely get into the oil, in this case. If the fuel pressure in your car is too high that may cause gasoline to get into the engine oil. So check if the float in the gas tank is rising the way it should be rising or if it needs an adjustment. Check whether the oil level might be really high, or else this can cause problem.
Check Piston Rings: If you realize too much gas is entering your engine, you should replace the piston rings and replace the oil.
See if these help your problem, if not, investigate other possibilities of fuel leaking into the oil. Try for fuel injectors test, and check the spark plugs also. Else you can always take help of expert mechanics like Eurobahn BMW MINI Mercedes-Benz Audi.
Here is a great page to find the year of your Club Car:
What Year is My Club Car Golf Cart?
It includes serial number format and all Club Car golf carts from 1982 to 2017+
I agree with all these answers. The next one must be from BILL.
We need more info. Anything. Brand names? Type of engine?
It has a head- gasket, atop a crankcase with oil, with a dipstick that smells of gasoline.
However, no mention of the problem. Oil in the gas makes smoke, a real golf-course no-no.
Gas in the oil, like a bleeding ulcer, will kill you. Also, a golf-course no-no.
A top-mounted carb may seep past the rings. A side-mounted carb will drip on the floor.
A mechanical pump can leak directly into the sump. Its not fuel-injected,,, computers don't allow leaks !
Like the doctor says, FIRST you tell me the symptoms, THEN, I'll tell you the treatment.
When I change oil in my club car golf cart within a few hrs oil is milky white any answers,trying to fix it myself
Club Car…….. brand first two # ‘S of the serial number are the year built…………Bill the engine guy
Imagine your oil is acting as a seal to seal your piston rings to your cylinder wall gap. Once oil starts to get gas mixed in with it, it looses viscosity and becomes very thin like water and allows more gas in at an exponential rate. This normally happens on vehicles with poor oil change history. Engines running rich with way too much fuel in the cylinders will also act in this fashion as mentioned in the comments above along with piston rings and cylinder wall damage causing low compression where fresh oil will not be enough to seal up the gap.
Figuring out if there is an over fuel condition or a worn out cylinder condition is your next step, performing a compression test with gas in the oil will not prove out a weak cylinder, do a wet cylinder compression test by putting some fresh oil in the spark plug hole and see if it will help seal the gap from the top and disable the fuel from entering the engine completely.
The fuel tank vent does not vent properly and pressure builds in tank which forces fuel into engine.
I removed the ball and drilled the hole larger Problem fixed
Letzte 24 Stunden: 7
Letzte 7 Tage: 80
Letzte 30 Tage: 413
Insgesamt: 47,285
1 Kommentar
i have 1994 club car had fuel in oil,changed fuel pump now smokes and oil drips out exhaust ,runs good just smokes ,compression is 150 # ?
von hanerarchie
