Zum Hauptinhalt wechseln
Repair guides and support for the C650 series of Satellite laptops by Toshiba.
33 Fragen Alle anzeigen
No audio devices installed, probably after Win 10 update
hi Fixit guys
My sound was working just fine after the w10 upgrade...around 6-7 months, until one day .... no more sound and a little "x" appeared on the little speaker symbol in the systray...(where we normally adjust the volume) ... * I can't remember if this happened immediately after a windows update*... anyhow, when i try to open the sound adjustments using the little speaker symbol in the systray, the dialog box says: No audio devices are installed....
the windows trouble shooter pops up, tests the system, finds problems, fixes them, tells me to restart and all will be ok… I do… but still no change… other times the trouble shooter tests the system and says that there are no problems… ;-) typical mico&soft consistency…
To try and fix it, i have followed the numerous similar instructions around the net, even re-loaded windows (what a pain that was)... but still no sound, still little ‘x’...
The major problem I am encountering is that in the device manager screen, there is absolutely nothing that refers to sound or audio, ,, however in the ‘system devices’ list there is a heading: High definition Audio controller, I click it, it says its working properly, go to update driver, it searches the net and says that i have the latest driver installed... but still no sound...
So, your instructions, as well as most everyone else’s, say that there is a “Sound, video and game controllers” entry. But in this c650 pro, there isn’t…
So, I’m thinking maybe the sound card burnt out and the system doesn’t see it… I’ve searched google and ebay for a c650 sound card and it doesn’t seem to exist, which could indicate that its part of the mutha board… I’ve fixed plenty of hardware and software issues on this old girl over the years but I’m no techie, only bluffing my way through, successfully up until now…
So, do you have any suggestions on this one ???
Cheers
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Sometimes you install new drivers and a peripherical doesn't work.You go to system device and you see there is everything ok. Once it happened to me with an wireless card.Drivers installed normally but the card wasn't working(even the system kept saying drivers work normally..). I had to download manually the specific driver from the producer and the problem disappeared. Try to do the same thing with your audio card.Look for specific driver. Hope this will help!
War diese Antwort hilfreich?
Bewertung 0
Thanks Mario, I have done that more than once.
Unfortunately the system still refuses to acknowledge that there is anything audio in it. Even the device manager has nothing about audio... I'm afraid the sound card may be cactus ... :(
It's a 5-6 year old toshiba c650, used at least 10 hours daily for work and play, which over the years has survived more than 10 overseas trips, at least 3 falls from the hood of the car and various other smaller falls, like off the coffee table...lol, a smashed screen, 3 worn out keyboards, repaired/modified hinges... a couple of burnt out RAM chips and probably more injuries which I can't recall ... and it still goes like a trooper.
I strongly recommend TOSHIBA as far as durability goes...
Anyhow, the gf bought me a slick upmarket dell notebook, so now the big T is semi-retired, doing work and other non audio related stuff... Maybe I'll take it to the computer repair shop, just for sentimental reasons...
Bewertung 0
Antwort hinzufügen
player300 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 27
Insgesamt: 817
