Zum Hauptinhalt wechseln
An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
42 Fragen Alle anzeigen
loosen power and the oil light came on
I have a 02 v6 passat one day driven it .. it started loosen power and the oil light came on ,so I drove it to the mechanic and came back . They said engine was locked up and have to have a new motor, but I can turn motor by hand so I know it's not locked up.. what could it b ?? I've heard of many things read many things anyone who had the problem email me at Jongfella@gmail.com.. thank you
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Jon Jon, If you can now turn the engine over by hand, it does sound like the engine is not locked up. But if the oil pump failed or you ran the engine low of oil and continued driving when oil light came on there could be internal engine damage/wear. Did the first mechanic say whether the engine was low on oil or pump failure or why he felt engine had locked up. If car is not starting and you can not trust what the first mechanic/shop told you, get a 2nd or even 3rd opinion. The shops may have to pull oil pan or use video scope to see/verify what damage's are done and to what extent. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Jon Jon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 14
Insgesamt: 88
