xiaomi qicycle battery replacement
where can i buy qicycle battery ? or how can i open the casing of the battery cause 18650 type is easy to find in my country.
Ist dies eine gute Frage?
There are several telegram chats with battery mods.
I’m running with a mod that allow to travel with 2 battery at the same time and hot-swap between then without powering down the bike. I can reach +80km distance (6ah+12ah)
https://3dparts459136784.wordpress.com/
Xiaomi Qicycle Custom Mods
War diese Antwort hilfreich?
could you show close ups of the structure that holds the batteries together. A tear down of the parts that keep the battery together would be nice too!
I fixed mine with a drill, once I saw back light flicker I put the charger on.
Hi did you spin the front wheel in the reverse way? Did you need to turn on the bike power to get back-light on?
Image above
How to release that casing batery ...give me step by step to do that..
They do appear on aliexpress from time to time.
Here it is for you bit hidden on the page but is avaiable as a seperate item.
its under electric bike china if you put qicycle in the search look for the electric bike shop china seller under the bikes it also have it listed wont allow link on this page . look for the link that starts from $42 dollar as it in that one.
Still guys your answers don’t address the question. seanjoeakiller wants to know whether one can just open the case and put in 20 cells in order to replace the old ones. That would be much cheaper and probably would cost around 100$ instead of 300+ that the full battery pack costs.
Check step 17 here. Apparently, the battery case can open with some heating and "good vibrations" but you will probably break the one-time-use clips the case has in the process. However, if your battery is dead by now, it's the best thing you can try I guess and see if the case can be closed again after being opened before buying a brand new set of batteries with case costing $300.
Thanks for the direct link of the battery on Aliexpress... But... It s a ripoff as I get the full ebike for that price !!!
https://www.aliexpress.com/wholesale?cat...
This is a link to a search for the battery on AliExpress, you can find many replacements, with prices starting at $219.99 (USD).
The real problem with repair or recreation of these batteries is opening the unit without damaging it. I'd love to be able to open the battery unit and test the cells to see if one is faulty and preventing further charging.
I'm a hair’s breadth from buying a replacement battery myself, as my battery won't charge anymore and Xiaomi don't support the cycle in my region. But that $219+ replacement price isn't a small amount, so I'm struggling on without the battery for the moment.
I removed the battery, opened its casing, and split the battery in two as then it was within the air transport laws (Australia). I don't recommend this unless you really know your electronics. The cells are spot welded in place and can get hot when removing. I never got it to work again..
I have photos of seperated battery internals
Definitely NOT user serviceable then?
No wonder they never used this style battery unit again.
Thanks!
It looks great as usual. Thank you so much for sharing.
Letzte 24 Stunden: 4
Letzte 7 Tage: 27
Letzte 30 Tage: 101
Insgesamt: 15,116
1 Kommentar
With increased interest in e-bikes generally, the cost of replacement batteries needs to be addressed. Proprietary brand battery replacement costs can run up to $1,000. There needs to be a rebuild option and iFixit would seem to be a perfect forum.
von Joseph Dice
