My volume button is going into my phone and is stuck
My volume button is stuck and is getting pushed into my phone. When I restart my phone, it is under safe mode cause my volume button is stuck. I can't disassemble the phone cause it comes in one piece of metal.
How should i unstick the volume button?
Ist dies eine gute Frage?
11 Kommentare
All phones appear to be one piece, but haven't seen any that can't be disassembled. I left my advice down below (SputnikBites) for how I handled the same with my power button. You just have to be patient & try different things. May take hours of fiddling until you notice progress because there's likely built up gunk to get it back out of. Just be careful with any of the steps. Once the volume button is out, the safe mode issue will be a simple fix. I would not start disassembling the phone unless you have some practice and understanding of such. You can easily ruin it. Check the Google/Facebook/Yelp reviews for businesses that will do it. Nowadays it's so much cheaper for simple repairs. It used to cost so much that it cost the same to replace the phone. A lot of things are only $50-$100 now. My friend went to Verizon because his camera lens cracked. They said he had to replace the one-year-old phone ($1000). I said BS and looked on Google. An hour & $50 and it was all good as new, and that included parts!
von Sputnik Bites
What did you end up doing? My wife is having the same problem.
von Sheri Swails
i have same problem with new galaxy s10 plus…its stuck and its stuck in safe mode
von lulaberri
My S8+ is doing this, were you able to fix yours?
von Haley White
i have same problem with galaxy a20s
von Zian Abdul Patah
6 weitere Kommentare anzeigen
