How to reset frp
How to remove frp from nexus 5x
Ist dies eine gute Frage?
Where are you located? Also there are ways to bypass it. Check if you can click on share when highlighting for example the wifi password enter in with show password for example.
I'll walk you through on what I mean.
So when you are on the welcome setup screen go to the page that prompts you to connect to an wifi network.
On that screen you will want to select a network then type some characters in then tick the box show password.
Then you tap and hold on that password entered and then click on share. There you will want to type in chrome and select the chrome app.
If you can do that then frp lock is easily bypass able on there.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 28
Insgesamt: 2,002
1 Kommentar
YOU CAN TRY THIS METHOD WITHOUT PC
https://frpbypass.net/bypass-frp-nexus-5...
von abouza ucf
