Zum Hauptinhalt wechseln
LGs Flaggschiff-Smartphone mit einem einzigartigem herausschiebbarem Akku, abnehmbarem I/O Modul und Unterstützung für mehrere Hardwareerweiterungen. Erschienen im April 2016.
146 Fragen Alle anzeigen
poor wifi and bluetooth signal after screen replacement
hello,
after a screen replacement with a refurbished one, now i have poor wifi and bluetooth signal on my lg g5. i suspect an antenna issue. someone know what could be the matter?
Ist dies eine gute Frage?
Bewertung 2
2 Kommentare
hello, thank you for your kind reply. Do you know where can i find the wifi/BT antenna in the logic board?
von
Hello
I have the same problem, did you find a solution?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
yup sounds like the antenna. order a replacement and swap it over.. if this doesn't fix it, will most likely be a logic board issue. 90% of all cases on the device is the antenna.
furthermore make sure you reseat the antenna connection.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
8 minutes ago by Gabriele Filoni
von
I had exactly the same issue. Check the antenna cable, it is under the motherboard, one of the connectors was disconnected, in my case and that solved the problem. Probably, when I was replacing the screen I accidentally disconnected the cable.
Bewertung 1
1 Kommentar:
Thank you very much it works!
von
Antwort hinzufügen
Gabriele Filoni wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 17
Insgesamt: 1,116
