Zum Hauptinhalt wechseln
Repair guides for the Saitek X52 Pro HOTAS (hands-on throttle and stick) game controller. The controller was released by Saitek.
21 Fragen Alle anzeigen
Throttle buttons stop responding in certain positions
My X52 pro acts up in certain throttle positions.
the rotator axis will change and loose accuracy in certain positions with the throttle Axis and some of the buttsons stop working as well. I believe it may be an issue with its internal potentiometers but I'm not entirely sure.
And to add to this I've owned this X52Pro for about two years now.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I AM PHOENIX that will depend which buttons etc. I suggest that you disassemble it using this guide Saitek X52 Pro öffnen and take a look at anything that may cause a mechanical reason for it binding. If there is none you will have to consider replacing the pots. This video might help you with that task.
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Thanks I'll try it out.
von
Also to be more specific it's the center button next to the throttle slider and it's also affecting the throttle hat.
von
Ok i took a look and all it shows is the main stick disassembly. The isssue is with the throttle. This issue doesn't affect the main joystick.
von
Sorry about that. Take a look at the throttle detent mods on here. It will show you how to get into and inspect it
von
Antwort hinzufügen
I AM PHOENIX wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 539
