Zum Hauptinhalt wechseln
US models went on sale as a 2012 model year vehicle. Early models include a choice of four-door sedan or five-door hatchback body, 2.0-liter DOHC (148 hp) engine, five-speed manual or Lineartronic CVT with paddle shifting six-speed manual mode.
6 Fragen Alle anzeigen
Key will not release
2013 Subaru Impreza
Key will not release when we shut the engine off. We have already troubleshot several steps. Brake is applied, transmission firmly in park, pushing key inward while turning engine off. Engine shuts off but will not complete cycle so that it can be removed.
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar:
Hi don, is the steering wheel locked? Make sure that is can turn a full 360.
von
Einen Kommentar hinzufügen
3 Antworten
If it has a locking steering column, the wheel may be turned too far. Turn the key while jerking the steering wheel back and forth fractionally.
War diese Antwort hilfreich?
Bewertung 0
Included with the above recommendations, I depress the brake pedal while removing the key. This might help.
Bewertung 0
I had this issue with my 2016 Impreza. After pulling apart the center console, I figured out what was causing my issue.
To move the shift knob the driver needs to squeeze in the button on the front (blue circle in the picture). This lifts up a rod through the knob (red line in picture) . with the rod up the shift knob can be moved into gear. The rod also presses a button when in park, releasing the key. My issues was the rod was not dropping all the way down and activating the switch. I pulled the rod out and put some light grease on it, hasn’t been a problem since. It was not to much work to get the rod out but I don’t remember exactly how.
Sorry its so late, maybe this will help someone else
Bewertung 0
Antwort hinzufügen
don fagan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 21
Letzte 30 Tage: 78
Insgesamt: 5,738
