Zum Hauptinhalt wechseln
The B6 and B7 versions of the Volkswagen Passat are front-engine large family cars produced by Volkswagen, a German automaker. The B6 line of the Passat was produced between 2005 and 2010, and the B7 line was produced between 2010 and 2015 as a facelift of the B6 line.
28 Fragen Alle anzeigen
Key fob stuck in ignition
Just replaced the battery in my key fob. I got into my car with the normal key, put the fob in the ignition and now it won't come out. Evidently I need to reprogram, but how can I get the key fob out?
Update (10/20/2017)
I realized my car battery was the issue. It was flatlined.
Left headlight was staying on even with key out.
So that seems to be the main issue.
I was able to get the key fob out after jumping the car.
So just trying to find a solution now for the headlight issue.
May disconnect headlight for now so it doesn't continue to drain battery.
Ist dies eine gute Frage?
Bewertung 3
3 Kommentare
this worked for me omg thank you so much
von
Glad it worked, pass it along...
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Push on brake and hit button forgear shifter a couple of times.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Yes, I had tried this already but it had not worked for me.
I had seen a video showing that.
It would have been great!
Thanks
von
It worked for me. Thank you!!
von
Its answer is pretty simple.
Move your car backward and forward again.
Make sure your handle face front. DO NOT LEAVE YOUR CAR WHEN YOUR WHEEL IS TURNED.
Bewertung 0
2 Kommentare:
I was programming my remote key fob now the fob is stuck in the ignition
von
I was programming my key fob and now the fob is stuck in the ignition I can’t get it out
von
Is there a battery in the fob?
If the five won’t come out of the ignition?
Bewertung 0
Antwort hinzufügen
Darby Rosello wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 109
Insgesamt: 20,710
