Zum Hauptinhalt wechseln
Repair guides and support for motorcycles manufactured by Harley-Davidson.
77 Fragen Alle anzeigen
rear brake engaging after riding for aprox. 25 minutes
My rear brake get extremely hot and self engages braking the bike after riding aprox. 25 minutes . I have bled the brakes several times with about 2 pints of dot 5 to remove any air and this continues to happen . 1999 softail . Suggestion please !
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@hel69 check your caliper to make sure it is not seized and continues to apply the brakes during normal driving.
War diese Antwort hilfreich?
Bewertung 2
3 Kommentare:
Thank you i will continue using the brake I did let some pressure off after riding when it was binding and hot. I think it helped.
von
I have bleed the rear brake many times and still it closes when hot .I'm thinking maybe the rubber hose is collapsing when hot . ill continue to work at it . thanks anyway
von
@hel69 that sounds very reasonable. Let us know what ended up working for you.
von
Antwort hinzufügen
Harry Helmly wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 290
