Zum Hauptinhalt wechseln
Apple AirPods sind kabellose Kopfhörer, die im Dezember 2016 auf den Markt kamen.
95 Fragen Alle anzeigen
Help I washed my airpods in a washing machine
Guys my AirPods and airpods charging case I washed it in a washing machine bymistakely forgot I had it in my pocket help…the green led light is not illuminating it doesn't work help if any one has any solution about it plz do share
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
My suggestion would be to put them in a bag of rice overnight. The rice will help draw out the water. If this doesn't work then I'm afraid you will need to buy a new pair since the water has likely killed the electrical components. It might also be worth letting them stay in the bag of rice for a few days. Good luck!
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
That is a myth. Rice is not a desiccant, and only blocks air flow. Keep them warm with a lamp and fan.
von
I save those little packets of stuff that keeps stuff dry hahaha u know the little bags of it says don't eat blah blah n I have a med bottle full I used bef
von
Antwort hinzufügen
Ali wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 53
Insgesamt: 27,309
