Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Saab
10 Fragen Alle anzeigen
Why is the blower fan not working
I have not been able to get the blower to run. I have a 2003 9-3 se convertible turbo.
Unit has climate control , I first started out thinking the basic, replace the resistor. Did not fix the problem. This resistor has power to both side of the wiring. There is a brown and a reds wire. Then the two wire from the fan motor. Then I replace the fan thinking intermediate problem. Still no fixed. I am pointing the climate unit but it seems to be working fine for all that it operates! I am stumped what can I look into, and is there suppose to be power present on both brown and red wires. Help!!!
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
any saab techs on this site that can answer a question why is there still power on both sides of the blower fan resistor !!!
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@srosario post some images of what you are seeing and checking. Not sure what to make out of the power situation you describe and show us where there is power is when you measure. Here is the schematic for Saab 9-3 Heating and vent controls
110 = Heater and ventilation controls
  • a=recirculation switch
  • b=heated air window switch
  • c=air conditioning switch
  • d=fan speed selector
111 = Recirculation flap motor
112 = Ventilation fan
23 = Dashboard Integrated Central electronics
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Sam Rosario wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 5,588
