Zum Hauptinhalt wechseln
Repair guides and support for the first generation Nissan Murano, from the 2003 model year to 2007.
19 Fragen Alle anzeigen
My 2005 Nissan Murano is not accelerating over 60mph on the highway?
Hello there, so I had an issue initially with my throttle body, got it replaced. After replacing it, I keep getting a code about idle re-learn. I did the procedure correctly to set off the engine code. Now my 2005 Nissan Murano is not allowing me to go past 60mph when I get on the highway. After replacing the throttle body and re-learning the idle, my cars acceleration isn't up to par and I can't figure out what it is that's preventing me from getting this fixed. Appreciate everyone that reads this, any feedback would be helpful. Thank you
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Had similar problem, had rpm but not much speed. Would take longer time to get up to speed( 60 mph). Found that the cvt ( tranny) was bad, new tranny problem fixed. Also check voltage, bad alternator , low voltage, than you get no rpm when stepping on peddle, also could be battery with low voltage( bad or shorted cell) The cvt is excellerate by wire( voltage), no or low voltage , no speed. Hope this helps
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
David Mendoza wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 33
Insgesamt: 4,167
