Zum Hauptinhalt wechseln
Reparaturanleitungen für Fahrzeuge der Marke Chrysler
194 Fragen Alle anzeigen
Why is my 2011 chrysler 200 heater blowing warm on one vent?
2011 chrysler 200 my heater is only blowing warm out of the drivers vent only. The rest are blowing cold. it is Not dual climate, it is a single climate control. the defrost, floor well all of it blows cold but drivers vent . when it runs warm then it blows a lil bit warmer. I'm freezing in my car. Any ideas?
Ist dies eine gute Frage?
Bewertung 2
4 Kommentare:
I changed the two actuators on my Chrysler 200 and still have heat on drivers side and cold on passenger side. What else do I need to do?
von
We had our 2011 Chrysler taken apart at the shop last year to fix this issue . . . still does the same thing. Blows hot on driver’s side but cold on passenger. It does warm up slightly after a bit. I noticed that the water temperature gage dial stays between C and midway (at 8:00 position) except when it idles for more than 20 minutes sitting in the drive. Then, the heater works great. Almost as soon as we take off, the gage goes back to the 8:00 position and the air on the passenger side is cold again. What the heck? Please, somebody figure this out. Forum posts indicate this is a default situation on this vehicle across the board.
von
Did anyone figure this out? My 2011 Chrysler 200 is doing the exact same thing
von
Do you have the trim level for individual environment control?
von
Einen Kommentar hinzufügen
2 Antworten
Be certain it isn't a mouse nest. 2 different cars and 2 motorcycles have been my victims.
War diese Antwort hilfreich?
Bewertung 0
I would say your thermostat is stuck. Check to see if it's running at normal temperature.
Bewertung 0
Antwort hinzufügen
Billie s. wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 6,451
