Zum Hauptinhalt wechseln
Premium 11-inch laptop with a 4k touchscreen and movable screen. (Model: L15W-B1208X)
3 Fragen Alle anzeigen
I get a message that says to reboot when I turn on my laptop.
When I turn on my laptop the Toshiba logo comes out as normal but then it turns all black and a message comes out that says “reboot and select proper boot device or insert boot media in selected boot device and press a key”. I have tried several things. There was one method that worked for many people and it was to go to the bios menu, disable the secure boot then go to system configuration and change the boot mode from Uefi to csm. I went to the bios menu and disabled the secure boot but when I go system configuration the boot mode tab does not even show up. I have no idea how to fix my laptop please help.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Your Harddisk is probably dead, how long do you have it? You can try getting the hard drive out and plugging it in a pc and see if it gets connected. If not: its probably dead. If that is the case, just replace the harddrive and install Windows
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Monica hernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 198
