Zum Hauptinhalt wechseln
Tipps, wie du iFixit optimal nutzt
24 Fragen Alle anzeigen
4mm Bit extension options?
Hello,
My BF had gotten me the 54 Bit Driver Kit from Ifixit years back as a gift and I've lost count on how much money it's made me between my two jobs and my moonlighting, but I recently got into more miscellaneous electronic repair and scrapping and a lot of the stranger devices/appliances require a longer/thinner driver than the Ifixit one. Does anyone have any suggestions for a good, durable extender that doesn't add much thickness, or even a different longer driver that I can also carry with me?
Thanks,
Derek.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
5 Antworten
Gewählte Lösung
See https://meta.ifixit.com/Answers/View/103...
I asked a similar question on iFixit Meta some months ago and came across you question in searching for it again. I was told my suggestion would be put to the Tools Dev Team but haven't heard anything since, which is a pity because I have a birthday coming up.
War diese Antwort hilfreich?
Bewertung 1
Hilfreichste Antwort
Wiha makes one called System 4 Magnetic Extension Blade for Micro Bits Part# 75901 its super narrow for getting into recessed screw cavities and can be stacked to reach even further. The only setback is its not very magnetic so you might have a hard time picking up larger screws.
Bewertung 2
2 Kommentare:
Bradford, thanks for the recommendation. Picked up a couple of Wiha 75901's from Digi-Key, and has already proven useful for opening a game console. Good stuff.
von
where can I buy it
von
I bought a specific Torx set with about 5-6” shafts which eliminated the extender bulge. Many times ANY bulge will create a problem so I would look for what you need with the long shaft instead of an extender.
Bewertung 0
1 Kommentar:
Indeed, the ideal is to have the right screwdriver for every screw - fine if you're in your own workshop with plenty of space for storing a galaxy of tools but we're not always lucky enough to be able to enjoy that. Before the pandemic (and hopefully again in the coming months) I used to attend pop-up community repair events, often travelling by train and/or bus and sometimes up to a mile's walk, and with no idea what challenges I might face. Along with all the other tools, it's then necessary to maximise usefulness whilst minimise weight and bulk, and a driver and set of bits is then the only sensible option and an additional range of long screwdrivers is not an option.
von
Hi @pleriche ,
I also attend community repair events and I’m also looking for a solution.
The solution proposed by @cspanpacman seems reasonable but I'm afraid that the buldge would still cause problems, like @ruggb emphasized (at least for the skinniest bits).
How do you manage this problematic in the meantime of an optimized solution?
Personally I was lucky enough to always have a fellow repairer that comes with his huge tool case ready to lend me longer shafts. But I would be more confortable to have an skinny extender. In terms of production footprint (and cost for our wallet) a good extender would save lots of long shaft versions for each bit we could need…
Do you think a good extender would be impossible considering the (failed) attempt of iFixit’s tool development team? (https://meta.ifixit.com/Answers/View/103...)
In short for future folks coming here, according to you, what kind of conclusion could we make about this problem ?
Best regards,
Geoff
Bewertung 0
1 Kommentar:
Hi @geoff5 - I still don't have a real solution. I have a set of 50 75mm 1/4" bits that I usually take with me, but they add a fair bit to the weight and arn't always long enough. You would have thought it'd be possible to make an extender consisting of 6 pieces to grip the bit inside a thin but very high tensile band to hold them together. But what do I know?
von
Note that as of February 2022, the Wiha magnetic extension suggested by Bradford May 2021 has been reported by DigiKey as discontinued by the manufacturer.
Bewertung 0
Antwort hinzufügen
Derek wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 85
Insgesamt: 2,387
