Zum Hauptinhalt wechseln
The sixth-generation Volkswagen Jetta, known as the NCS (New Compact Sedan) during its development, was announced in the North American market in June 16, 2010.
19 Fragen Alle anzeigen
Inspection light on after oil change
I have checked all the fluids and replaced the oil and oil filter. Now I have an inspect (Inspection light on) in dash. I tried to reset and it remains on during starting only. Can someone tell me what I should do next?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
1 Kommentar
The rest process did not work for me(wrench).
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
For Keyless Start:
Start with car turned off:
1. For Inspection Reminder Reset: Turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and push the Engine Start button (without starting engine - foot off brake).
2. For Oil Change Reminder Reset: Don't turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and push the Engine Start button (without starting engine - foot off brake).
For Key Start:
1. For Inspection Reminder Reset: Turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and Turn key to "ON" without starting the car. Look at dash for further instructions.
2. For Oil Change Reminder Reset: Don't turn on Emergency Flashers. Then press and hold Reset/0.0 Button on instrument cluster and Turn key to "ON" without starting the car. Look at dash for further instructions.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
I did this and acts like it reset then the warning comes back on seconds after resetting.
von
Same. It just removed some of the letters in the warning.
von
Thanks heaps. My oil warning light appeared after using jumper leafs on to my sons car. Using the reset emergency flashers/ 0.0 set on dash and putting key into start mode without starting did the trick!
von
For vehicles with ‘Basic Display' (wrench icon and INSPEC_ message)
Reset the Inspection reminder:
1.Switch off the ignition.
2.Switch on the emergency flashers
.3.Push the . button in the instrument cluster and hold down.
4.Switch on the ignition.
5.Release the . button and push the  button in the instrument cluster within about 20 seconds.
6.Switch off the emergency flashers.
To reset Service reminder:
Same process except don't activate hazard lights.
P.S. don't reset Service indicator unless the vehicle has been serviced or incorrect data will be displayed.
Bewertung 1
1 Kommentar:
the magic word is 20 sec after the wrench Inspection appears
von
I reset mine and all is fine for approx two weeks then it tells me I need an oil change again! Any Clues?
Bewertung 0
1 Kommentar:
You may in fact have too much oil. Apparently their are minor diesel leakage from the injectors into the oil in Amroks. Oil builds up and triggers the warning light. The sensors are really sensitive to excess oil levels.
von
Antwort hinzufügen
g3houdini wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 39
Letzte 30 Tage: 212
Insgesamt: 85,542
