Zum Hauptinhalt wechseln
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
18 Fragen Alle anzeigen
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
My breaks ar light weight
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Joseph Fernandez wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 699
