What fuse is for the Cigarette lighter
What fuse is for the cig lighter
Ist dies eine gute Frage?
@michmadman6969 should be part of the Convenience Center (fuse box interior left side of dash). According to the wiring manual for your model it is marked as CTSY
War diese Antwort hilfreich?
10 amp fuse, this will be found if you check the fuse in the cab not under hood and check for sure and read the diagram to check which to pull out and if you cant read google that $@$* too
It's a 10 Amp, I have a 20 Amp in mine. And there should be another Fuse panel, when you open the drivers side dash board a little panel which got me too, all your other fuses are there.
Found out the Hard way $$$$
15amp fuses should work. If It does not, look on the side.
Hi @allenrhayes
Check fuse #53 engine bay fuse box. It's the one with an image of a smoking cigarette and 12V marked underneath it.
Hello John,
The fuse is usually labelled as Cigarette Lighter, The fuse number cannot be given as you did not include a Year or model # in your question. The fuse block is usually located inside the cab on the drivers side however.
Good Luck,
Rich Lilja
Its a 1991 chevrolet gmt 400I. It isn't marked in the fuse panel. Was told the radio fuse but the radio works fine
it is a 2010 chevy silverado 1500
Letzte 24 Stunden: 4
Letzte 7 Tage: 55
Letzte 30 Tage: 228
Insgesamt: 20,299
4 Kommentare
@michmadman6969 what exact year is your Pickup
von oldturkey03
von John Ladd
2005 dodge caravan i need to know wut kind of fues do i get for the car lighter
von millie
88 chevy s10 pick up the cig light doesnt work what and where do i change the fuse
von IronboundFool15 The Original
