Zum Hauptinhalt wechseln
The second generation of the Recreational Active Vehicle with 4-Wheel Drive, commonly known as the RAV4.
22 Fragen Alle anzeigen
How to improve 2002 rav4 gas mileage?
I have replaced maf,o2sensors,(4 of them)
,new plugs, new coils,new catalytic converter, air filter,throttle body (small gasket),tire pressure,pcv, new exhaust ..gas mileage is still quite poor ..is their something else I can check..had several shops scan all come back good..??????
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
@lynxster what gas mileage are you getting?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
@lynxster This is an SUV that is currently 12 years old. The original MPG based on the old MPG measuring standard 25 mpg vs the new standards which makes it around 22mpg. Give it another 12 years, and that would drop to about 17mpg.
What MPG are you getting?
Have you cleaned the fuel system (i.e. fuel lines, fuel filters, fuel injection system)?
Have you made sure your tires are properly inflated? This actually makes quite a difference sometimes.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Lynxster Limbo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 1,355
