Zum Hauptinhalt wechseln
Geschirrspüler von Bosch. Modell Nr SHU5315UC-06
12 Fragen Alle anzeigen
led display and lights do not work
Have a Bosh logixx dishwasher, It will function by the power button. So will do the job and turn itself off etc........It is meant to have a count down timer on the led display etc but the display and lights are not working.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Have you tried to dissemble it and check pcb? Connectors and fuses especially?
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I could not find a manuel guide with a picture...do you know where the fuse are located?
I was thinking it could be a fuse but also need the type of fuse
von
no replaceable fuse on this unit . check connections from the pcb to the lights or replace pcb
Bewertung 0
Antwort hinzufügen
Mark Marriner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,142
