Zum Hauptinhalt wechseln
Reparaturanleitungen und Hilfestellungen für alle Arten von Batterien und Akkus.
74 Fragen Alle anzeigen
Is there a discharging device for this gopro karma drone battery?
Is there a way of building a discharging device for a gopro karma battery (gopro karma is a drone) like a bulb that will discharge the battery. The connectors are different and I have not seen anything about it. There are other batteries that has a simple connectors but this one is a bit different.
Update (05/15/2018)
The purpose of having a discharging device is to discharge the battery to a certain voltage so as when you store the battery, the battery life is extended. Of course you discharge it when you have to store the battery for a longer period of time. I have seen some attachments to other lipo batteries to discharge it but I have not seen one for this particular battery. So, is there one out there?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Just curious ,why discharge it?
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
You could always use the karma as a discharging device and run the karma for a few minutes before removing the battery and storing it on a shelf for an extended period of time. Otherwise, you could try interfacing to the battery connector and plug in a ~15v fan to discharge the battery.
Good luck!
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
edbaradi wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 251
