Zum Hauptinhalt wechseln
The most popular option to light large areas of buildings. They come in a variety of connection types and power ratings.
22 Fragen Alle anzeigen
What fluorescent starter to use with 9 inch fluorescent tube
I’m trying to get an old beer sign light to work. It has a small 9 inch tube. There was no starter, so I bought and tried a FS-5. It immediately blew the bulb. I think I must have the wrong type of starter
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
So it turns out that some form of a ballast or something else is in the power cord. Again this is a very old beer sign so it likely is not the way they do it now
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Hi @jsanger
Some interesting Read
https://unvlt.com/pdf/literature/trouble...
Would be great if you can share more pictures.
Else another suggestion, to modify the current lighting to use LED modules.
If you use LED, you can remove away the ballast, if you had tested the ballast has failed, so as the starter.
Just for your reference.
https://www.amazon.com/Fulight-Rotatable...
War diese Antwort hilfreich?
Bewertung 2
This beer sign light does not have a ballast, just a starter. How do I share a picture
Bewertung 0
1 Kommentar:
@jsanger use this guide Bilder zu einer vorhandenen Frage hinzufügen you need to edit your question and add the images to the question.
von
Antwort hinzufügen
Jeff Sanger wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 7
Insgesamt: 116
