Zum Hauptinhalt wechseln
Stühle und Sitzgelegenheiten für Terrassen, Balkone und Junggesellenbuden.
3 Fragen Alle anzeigen
Damage to clear chair
There was a number written on bottom of clear acrylic chair I purchased. I tried to remove it first with glass cleaner. No luck. Then I used nail polish remover. It removed writing (looked like black sharpie) but left area foggy, no longer clear. How can I restore?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Nail polish remover generally contains acetone or ethyl acetate both of which dissolve plastic. You could possibly buff it out but you are going to make a much larger area involved. IMHO further repair attempts are going to be futile. Live with it.
War diese Antwort hilfreich?
Bewertung 5
Lookup a technique called "chemical polishing". It uses a solvent of the material and a way of "rolling" the papertowel / rag so only fresh solvent is wiping the surface. I do it on car headlight lenses, but it took a fair amount of practice. I use a liquid acrylic glue, but straight acetone should work.
Bewertung 1
Paint Thinner - oil based, great discoloration remover and will make the PVC or plastic shine - use dawn dish detergent to clean the oily residue after you remove all the stains.
Bewertung 1
Next time try ISO alcohol. I find it removes permanent marker ink.
Bewertung 0
Antwort hinzufügen
Marilyn Hartley wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 66
Insgesamt: 1,789
