Zum Hauptinhalt wechseln
First generation, based on the Ford C1 global platform.
36 Fragen Alle anzeigen
Bell housing bolt patterns at Vs mt
My 2006 Mazda 3 threw a rod. I'm looking for a replacement engine. What I need to know is if I can get an at engine for my manual car and just swap the flex plate for the flywheel. I've heard rumors that the bell housings are different. Any help would be greatly appreciated. Thanks.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Ok awesome thank you so much.
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
As long as you get the same motor then it should just bolt up , doesn’t matter if it was auto or standard . you will have to change the flywheel ,just use your old one . you will also need the spacer plate for the starter from your old engine (depending on the year) as well
War diese Antwort hilfreich?
Bewertung 3
Antwort hinzufügen
Luke Jensen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 14
Insgesamt: 173
