Zum Hauptinhalt wechseln
Refrigerators produced by Samsung.
258 Fragen Alle anzeigen
Ice Maker not dumping
Ive seen a few similar questions on here but no exact answer to the problem that I have.
Samsung Fridge Freezer not dumping the ice from the tray to the holder. It makes the ice but will not dump unless i press the test button then it will turn, dump and refill.
The ice making unit is new. I had removed the old one due to a broken tray about 3 months ago so the freezer has been sitting with no ice maker and switched to ice maker lock.
The freezer is set to 2 degrees and both fridge and freezer temp work fine.
is it possible the time its been left unconnected has put some ice somewhere it shouldnt?
Can someone confirm if it could be the icemaking unit that is faulty or is it another part of the freezer not working?
Please let me know any thoughts, i will be on here regularly checking for answers.
Thanks in advance.
Ist dies eine gute Frage?
Bewertung 2
5 Kommentare
@darrenb what exact model is this?
von
here are the details on the inside of the fridge.
e-nr KA58Na40gb/06 FD8609 serial no 000229
von
Has it ever worked?
von
yes it worked fine before i removed the old ice maker when the tray broke.
von
would be great if someone could give me an idea on how to fix this....
von
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
If the old one worked and the new one does not, I suspect that you got a defective unit. I’d return it and buy from a different source.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
thanks but is the part the part that decodes when to empty in the ice maker ? or the freezer?
von
the ice maker board
von
Antwort hinzufügen
darren wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 93
Insgesamt: 6,998
