Why does it continuously vibrate when charging?
Sometimes, after the phone is completely dead, when I plug it in to charge, it just vibrates and does not charge.
Ist dies eine gute Frage?
You're 100% correct. My S9 will vibrate continuously and not charge when the battery is completely dead; however, I was using a USB hub to charge the phone. When I use the power adapter that came with the phone it works just fine. My guess is a completely dead battery requires a specific amount of power to charge correctly. After that, the lower wattage USB charger works just fine.
War diese Antwort hilfreich?
I was just about to send this, new to me, s9+ back to the seller. I grabbed a new cable today and plugged it in my usb multicharger and it continuously vibrated like it might blow up. After reading this post I plugged it into the block, then the outlet and its charging. Now up to 85%. Thank you so much for posting your information. It was 100% helpful. Awesome.
Maybe your port is bad. Does it happen when you wirelessly charge?
I agreed with this. It sounds like your port is bad, or your cable is not working properly.
Test
-Inspect your port for corrosion, LED Light and a magnifying glass and look for greenish substance.
- See if your port is clogged, if so use a toothpick and carefully remove debris
- Try different Cables, especially if your cable has exposed materials.
Nope I've got a bad port it doesn't do that so you can rule that out it only vibrates continuously when it detects moisture
It's detecting moisture I got that with my s9 hat to dry the charge port with a hair
I had the same problem with my phone I was using a chromebook charger to charge it and it was buzzing but the second I took out a regular usb to usb-c cable it starting charging.
Thanks so much, guys. Using the charging block and USBC-USBC cable that came with my newer Samsung A 54 worked. You saved my life. I was hyperventilating 'cause I have irreplaceable contacts and messages from my non-portable WeChat ID on my "ancient" but beautiful S9.
Letzte 24 Stunden: 21
Letzte 7 Tage: 196
Letzte 30 Tage: 847
Insgesamt: 53,440
15 Kommentare
von Sugriv Rai
Ofter contacting the charge Phone vibration continue
von Sugriv Rai
Worked for me
von Wilma Snider
im having the same issue wireless charging wont work neither do different cords or power bricks i havent tried my fast charger brick though(because i cant find it) but before all this my phone would reset randomly and it died at half charge a few times… my guess is i &&^&@@ something up when i did that self repair but its been fine for a month so….
von jax emery
Am having the same issues with me galaxy note 9
What you think may be the problem??
von Quietkidd13 DIY/BASSHEADS!?
10 weitere Kommentare anzeigen
