Zum Hauptinhalt wechseln
The McCulloch MC1275 is a heavy-duty canister steam cleaner that uses ordinary water heated to over 200 degrees Fahrenheit to clean and sanitize a wide variety of surfaces.
28 Fragen Alle anzeigen
Mcmulloch MC 1275 Black water in reservior
Is there a chemical I can use to clean out inside besides vinegar ? What about CLR
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
  • Manganese leaves brownish or blackish stains.
  • White vinegar, a weak acid, is about 5 percent acetic acid. It may remove hard water deposits from glass, rust stains from sinks, and tarnish from brass and copper.
  • Lemon juice, another weak acid, contains citric acid, which can be used in much the same way as vinegar.
  • Oxalic acid is effective as a rust remover.
  • Phosphoric acid is often found in cleaning products that remove hard water deposits.
  • Hydrochloric and sulfuric acids are sometimes used in diluted concentrations in toilet bowl cleaners. A dilute sulfuric acid is also called muriatic acid and used to clean swimming pools.
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Deb’sMistake wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 210
